P
Pro
2.4.1
P
Pro
2.4.4
P
Pro
2.4.5
Maps and Charts
- Fixed map startup so the map can center without waiting for a new location update.
- Fixed black screens and lifecycle issues in route editing, as well as track recording recovery and account switching.
- Refactored high-detail chart downloads and weather package download and installation.
Accounts and Startup
- Fixed login session issues and improved recovery and data isolation after account cleanup failures.
Architecture Refactoring
- AIS: Refactored AIS business flow orchestration and reorganized reception, vessel status, target display, and navigation flows.
Pro
You've been busy :)
Thanks, great improvement
Wishing you all the best
Cheers
Pro
Hi
S
Pro
Hi again!
Thanks for reporting this!
S
Pro
Pro
feedback
Pro
feedback
Pro
Feedback
deapth error
the deapth is not accurate
S
Pro
S
Pro
S
Pro
2.4.8 Beta
Pro
Thanks
Cheers
S
Pro
Thanks, Hassanein!
Cheers,
Pine
