Release Note 2.6.*
S Pro
Release Note 2.6.*
S 2 replies 94 views
S Pro
2.6.0 Beta Release note
What's New
  • Custom Map Layer Import: Import local MBTiles and offline/online SQLiteDB layers directly in Base Layers, with individual toggles, attribution editing, and deletion. Imported layers render above the basemap while keeping depth and nautical chart layers on top, backed by background file transfer.
  • Wallet & eSIM Flow Improvements: Wallet now automatically refreshes your latest balance and transaction history in the background upon entry. When eSIM checkout encounters insufficient balance, the app redirects to Wallet with the required top-up amount pre-filled.
  • Refreshed Launch Prompts: Upgraded launch prompts to a unified bottom-sheet design and added a global eSIM data tip.
Bug Fixes
  • Fixed an issue where total odometer distance in Settings did not follow the selected distance unit (NM / km / mi / ft).
  • Fixed an issue where the file picker failed to open after accepting the import disclaimer.
S Pro
v2.6.1 (IOS Release)
New Features
  • Standalone Voyage Statistics & Cloud Sync
    • Added independent voyage statistics tracking, with daily distance traveled and peak speed (calculated from two GPS points) stored persistently by local date. Supports automatic daily background cloud synchronization for logged-in users, merging records by retaining the maximum value for each day.
    • Added a voyage statistics calendar, achievement badges, and five fun distance milestones for comparison: Mount Everest's height, a full marathon, the Suez Canal, the length of New Zealand from north to south, and Earth's equatorial circumference.
    • Added shareable voyage achievement posters with a branded footer featuring the SeaChart icon, official website, and download QR code, optimized for both portrait and landscape orientations.
  • Dedicated GPS Speed Trend on Dashboard
    • Replaced the dashboard's barometric pressure chart with a dedicated GPS speed trend chart, while retaining the standalone barometer feature.
    • Records GPS speed every 5 seconds for up to 1 hour, with selectable 5 / 30 / 60-minute time windows and support for global speed unit settings.
    • Prevents misleading line connections during GPS signal interruptions and filters abnormal speed readings.
Improvements & Enhancements
  • Dashboard & Speed Trend Visuals
    • Improved speedometer and speed trend typography by emphasizing integer values, displaying decimal points and digits at 55% of the main font size with proper baseline alignment.
    • Redesigned time-range selectors as compact segmented pill buttons.
  • Voyage Tracking Reliability
    • Removed the 5-second delayed disk write mechanism and introduced immediate, sequential saving whenever data changes.
    • Added safeguards to preserve daily maximum distance and peak speed during saving, recovery, and data restoration.
    • Improved cloud synchronization to ensure non-zero voyage distances for the current day are uploaded again when necessary.
  • Ratings & Feedback
    • Redesigned the app rating dialog with a five-star display and added a direct entry point to the Feedback Center.
    • Improved localization across 24 supported languages.
  • Settings Page Experience
    • Refined the display order of values and labels for the mileage and wallet entries.
    • Improved arrow alignment and added ripple feedback for interactive elements.
Bug Fixes
  • Fixed iOS app update checking and App Store redirection logic.
  • Decoupled the login dialog from the app startup process to prevent startup interruptions.
  • Fixed an incorrect localization key that caused the Feedback Center dialog to display feedback_title instead of the proper title.
  • Added locally throttled diagnostic logs for voyage distance filtering to help identify why daily voyage records may not be generated.
