Release note 2.4.*
Discussão
2.4.1
2.4.2
- Improved app startup speed.
2.4.3
2.4.3 IOS version
mantap
2.4.4
2.4.5
You've been busy :)
Thanks, great improvement
Wishing you all the best
Cheers
What’s New in 2.4.6
What’s New in 2.4.7
Hi
Hi again!
Thanks for reporting this!
feedback
feedback
Feedback
deapth error
the deapth is not accurate
2.4.8 Beta
Thanks
Cheers
Thanks, Hassanein!
Cheers,
Pine
SeaChart 2.4.9
New Features and Improvements
Bug Fixes and Stability
