← 返回社区
图片与视频
H P 28 条回复 773 浏览
讨论
Thanks will test
failed to add to que
图片与视频
Features include:
  • Video preview
  • Play / pause controls
  • Draggable trimming range
  • Cancel and Done buttons
    • Landscape: 960×540
    • Portrait: 540×960
  • Preserves audio
  • Media source selection
  • Image / video selection
  • Video trimming
  • Media compression
6. Updated Upload Limits
图片与视频
图片与视频
图片与视频 图片与视频
图片与视频
图片与视频 图片与视频
回复
登录
