← Topluluğa dön
Fotoğraflar ve videolar
H P 28 yanıt 761 görüntüleme
Tartışma
Thanks will test
failed to add to que
Features include:
  • Video preview
  • Play / pause controls
  • Draggable trimming range
  • Cancel and Done buttons
    • Landscape: 960×540
    • Portrait: 540×960
  • Preserves audio
  • Media source selection
  • Image / video selection
  • Video trimming
  • Media compression
6. Updated Upload Limits
Fotoğraflar ve videolar Fotoğraflar ve videolar
Yanıtla
Giriş yap
