← Kembali ke komuniti
Foto dan video
H P 28 balasan 758 paparan
Perbincangan
Thanks will test
failed to add to que
Foto dan video
Features include:
  • Video preview
  • Play / pause controls
  • Draggable trimming range
  • Cancel and Done buttons
    • Landscape: 960×540
    • Portrait: 540×960
  • Preserves audio
  • Media source selection
  • Image / video selection
  • Video trimming
  • Media compression
6. Updated Upload Limits
Foto dan video
Foto dan video
Foto dan video Foto dan video
Foto dan video
Log masuk
