← Bumalik sa komunidad
Mga larawan at video
H P 28 sagot 768 pagtingin
Talakayan
Thanks will test
failed to add to que
Features include:
  • Video preview
  • Play / pause controls
  • Draggable trimming range
  • Cancel and Done buttons
    • Landscape: 960×540
    • Portrait: 540×960
  • Preserves audio
  • Media source selection
  • Image / video selection
  • Video trimming
  • Media compression
6. Updated Upload Limits
Mga larawan at video Mga larawan at video
Sumagot
Mag-sign in
