← Tilbake til fellesskapet
H P 5 svar 635 visninger
Diskusjon
The new batch menu includes:
  • Merge Routes
  • Move to Folder
  • Share
  • Delete
  • Cancel
  • Download them as GPX
  • Download them as KML
Svar
Logg inn
