P
Pro
P
Pro
At the moment, SeaChart does not provide a complete turn-by-turn navigation service, so registering it as a system navigation app could be difficult from an App Store review perspective. My current chart and data sources are designed to support marine navigation and situational awareness, but they do not provide the type of routing data required to generate true marine navigation routes automatically.
As an alternative, I plan to change the shared location link from a Google Maps link to a SeaChart-specific web link. I can then configure these links so that, when SeaChart is installed, tapping the link can open the location directly in SeaChart.
This should provide a much smoother way to share locations through WhatsApp or other apps without requiring SeaChart to be registered as a full navigation application.
Pro
Thank you for the response
This should work for seachart users but would exclude other navigation apps
Perhaps you could consider offer link format options
1 share as seachart link
2 share as Google maps link
3 share geo.
4 share coordinates
please see attached from Osmand
The objective is to make position sharing as flexible and usefull to as many people as possible
Thank you again
Have a lovely day
Pro
After thought
in addition to above post for choices, is there a way in the scenario whare a seachart link is sent to someone who doesn't have seachart installed, opening the link would give a message that it is not installed and offers to install
this may induced people to install.
Food for thought ;)
Have a lovely day
P
Pro
In the new version, shared SeaChart links will open a web page first. From there, users will be able to view the shared location and access additional sharing options.
Thanks again for the idea, and have a lovely day!
P
Pro
