← Torna alla comunità
P H 13 risposte 353 visualizzazioni
Discussione
Thank you for the detailed feedback. Your concern is completely understandable, and I would like to clarify a little more about how our weather data is currently handled. The original global weather dataset is approximately 30 GB for each update. Because this is far too large to distribute directly to mobile devices, our server first receives the raw source data, then processes it, performs the required calculations and forecast processing, and finally compresses and packages the results into a much smaller format suitable for use in the app. This entire server-side processing pipeline normally takes around one hour after the original data becomes available. One thing that can sometimes be confusing when comparing weather services is the timestamp shown to users. Many weather products display a "published" or "updated" time, but this does not necessarily indicate when the underlying weather model data was originally generated. In many cases, it simply represents the time when that particular service finished processing and published its own forecast product. For this reason, two services may display different update times even though their forecasts are based on the same, or similarly timed, underlying model data. We do agree with your main point that weather information should be refreshed whenever an internet connection is available, while downloaded or cached weather data is particularly useful when a user is offshore or otherwise completely offline. The app will also check in the background whether newer weather data is available on our server. If an update is available, the next time you open the weather feature you will see an update prompt. You can then choose either to download the latest data or continue using the previously downloaded data. We are also considering making the weather data more modular. For example, when you open the wind layer, the app could download only the wind-related data rather than the entire weather package. This would significantly reduce the size of each individual download and make updates faster and more convenient. We will also consider making the data time and update status clearer in the app, so users can more easily understand how fresh the forecast actually is. Thank you again for taking the time to explain your concerns and suggestions. They are very helpful.
To provide a little more context, weather forecast models do not all update at exactly the same frequency. However, many of the major global forecasting systems currently produce a new forecast cycle approximately every six hours. For example: • NOAA GFS / GEFS — 4 forecast cycles per day: 00, 06, 12 and 18 UTC. • ECMWF IFS — 4 forecast cycles per day: 00, 06, 12 and 18 UTC. • ECMWF AIFS — 4 forecast cycles per day: 00, 06, 12 and 18 UTC. • UK Met Office Global Model — 4 forecast cycles per day: 00, 06, 12 and 18 UTC. • UK Met Office MOGREPS-G Global Ensemble — also runs at 00, 06, 12 and 18 UTC. There are also regional high-resolution models that update more frequently. For example, NOAA's HRRR model for the continental United States runs every hour. Therefore, when we refer to an approximately six-hour update cycle, we are referring mainly to the major global forecast models rather than every weather model in existence. It is also important to distinguish between the model cycle and the forecast resolution. A model may generate a completely new forecast every six hours while still providing forecast values at one-hour intervals. Another important point is that the model start time is not necessarily the same as the time shown as "Updated" or "Published" by a weather application. After a new global model cycle begins, the source provider still needs time to complete and distribute the model output. Our server then receives approximately 30 GB of raw global weather data, processes the required information, performs the necessary calculations and forecast processing, and compresses and packages it for mobile use. Our processing stage normally takes approximately one additional hour. For this reason, two weather applications may show different "updated" times while actually using data originating from the same underlying forecast cycle. We therefore believe the most useful information for users is not simply the publication time, but the actual age of the underlying forecast data. We will continue looking at ways to make this clearer within the app.
Foto e video
Foto e video Foto e video Foto e video
Rispondi
Accedi
