← 返回社区
S Pro
S H P 7 条回复 339 浏览
讨论
S Pro
sir ASIA
Thank you for the suggestion. I have actually considered a similar approach before, and I agree that using different colours for different depth ranges would make the chart much easier to understand at a glance, especially on smaller screens. The main limitation is the amount of additional map data required. At the moment, most of the depth data is stored as lines and points. For example, a 5-metre contour is essentially stored as a series of coordinates forming a line, with the depth value attached to it. This is relatively efficient in terms of file size. However, to display coloured depth bands such as red for 0–5 m, orange for 5–10 m, yellow for 10–20 m, and so on, the map needs more than just contour lines. It needs to know the complete area between those lines so that the colour can be filled correctly. This means the line-based depth data has to be converted into many filled polygon areas. These polygons can contain a very large number of coordinate points, especially around complicated coastlines, islands, bays and irregular depth contours. Boundaries may also be repeated between neighbouring polygons, which increases the amount of data further. The original depth map file is currently around 500 MB. I previously tested adding a relatively low-precision coloured depth overlay, and even that increased the file size to around 800 MB. That is an increase of approximately 300 MB, or about 60%. Adding more detailed depth bands would increase the file size further. Since the app supports offline chart downloads, this would also increase download size, storage usage on the device, update time, and server bandwidth requirements. The colours themselves require almost no additional storage. The main problem is the large amount of polygon data required to define exactly where each colour should be displayed. For this reason, unfortunately this is not something I can implement at the moment, but thank you for the suggestion and for explaining the usability benefit so clearly.
回复
登录
