← Bumalik sa komunidad
Add Deutschland map [Copy From Google Play] Loads a huge basemap, just to give me a handfull of options which special areas i could download. None of which i will ever come even near to. Cant do anything without downloading additional maps which are not aviable for germany (there are multiple sources of maps for germany but none of them are in the app) Why cant i just use the basemap, if u cant give me detailed maps for my area? Worthless for me, wasted 2gb of roaming data!
P 2 sagot 254 pagtingin
Talakayan
Thank you for your feedback. We have now moved regional map downloads to the same screen as the basemap, so you can see supported areas when the app starts. We understand your frustration about roaming data. Germany maps are planned and expected to be available by the end of July.
Germany charts are now supported in version 2.0.2. The update has already been released, and you should receive the app update within the next 2 days.
Sumagot
Mag-sign in
