P
Pro
Thank you for your suggestions.
The Text Notes / Reminders on Chart feature has already been implemented.
You can long-press any point on the chart to open the popup window. In the popup, there is a Save button next to the Close button. You can use it to save that point and add your own note or reminder.
I will re-edit your requirements so we can track it properly.
The AIS target display request has already been recorded in a separate ticket, so we will continue tracking it there.
P
Pro
Manual Route Creation by Coordinates
Requirement:
Allow users to manually create a route by entering coordinate points, such as latitude and longitude.
Details:
Users should be able to input multiple coordinate points manually and generate a route from those points on the chart.
Example:
Enter waypoint 1: latitude / longitude
Enter waypoint 2: latitude / longitude
Create a route connecting the points
P
Pro
By the way, we recommend trying the GPX or KML import feature.
If you have multiple coordinate points, importing them as a GPX or KML file may be easier and more efficient than entering each point manually one by one.
P
Pro
Thank you for the suggestion.
We have tried to add this feature in version 1.5.1. Since the development time was quite limited, it has not been fully tested yet, but we believe it should work without major issues.
The update is expected to be released within the next 2 days.
