PAdd Auto Follow Function
Please add an Auto Follow function to the navigation map.
When enabled, the map should automatically follow and centre on the user’s current GPS location. If the user manually moves or zooms the map, Auto Follow should pause or turn off. The user should be able to tap the Auto Follow button again to return to their current location.
The Auto Follow button should clearly show whether the function is active or inactive.
