### 2.4.1
### 2.4.2
- Improved app startup speed.
### 2.4.3
# 2.4.3 IOS version
### 2.4.4
- **Offline high-detail chart downloads now use Z6 map blocks.** You can select areas on the map and track download status. Block loading, version cleanup, pause and completion feedback, and streaming checksum verification were also improved.
- **Overview chart downloads support the new API.** The update adds package parsing and validation, improves failure messages, and fixes navigation back to the home screen after an update.
- **Cloud sync after login shows actual merge progress.** JSON parsing now runs in the background, writes are batched, and the sync response limit is 20 MiB.
- **Fixed image upload compatibility** for some JPEG files that previously failed to decode.
- **Map display and download guidance improved:** contour colors were adjusted, and multilingual guidance was added for boundaries between high-detail chart download areas.
### 2.4.5
Maps and Charts
- Fixed map startup so the map can center without waiting for a new location update.
- Fixed black screens and lifecycle issues in route editing, as well as track recording recovery and account switching.
- Refactored high-detail chart downloads and weather package download and installation.
Accounts and Startup
- Fixed login session issues and improved recovery and data isolation after account cleanup failures.
Architecture Refactoring
- AIS: Refactored AIS business flow orchestration and reorganized reception, vessel status, target display, and navigation flows.
