↳ Reply 28 122 views
Thanks will test
failed to add to que
## 1. Added Video Posting Flow for Moments * Support recording videos and selecting videos from the gallery * After selecting a video, users are taken to the video trimming screen * Long videos allow users to drag and select the start and end positions * Short videos automatically skip the trimming confirmation step * Images and videos now use the same sending queue ## 2. Added Video Trimming Screen Features include: * Video preview * Play / pause controls * Draggable trimming range * Cancel and Done buttons * Loading state and error handling * Support for portrait video preview ## 3. Updated Video Compression Logic The video compression flow now: * Reads video width, height, rotation angle, and duration * Preserves the original video aspect ratio * Outputs portrait videos in portrait orientation * Current maximum output resolution: * Landscape: 960×540 * Portrait: 540×960 * Preserves audio * Fixes incorrect interpretation of Android trimming parameters * Provides clearer error messages when compression fails ## 4. Added Full-Screen Video Preview Controls When tapping a video thumbnail on the Moments compose screen: * Opens a full-screen video preview * Tap the video to play or pause * Adds a draggable progress bar at the bottom * Displays the current playback time and total duration * Uses a dark gradient, green progress indicator, and circular seek handle * Portrait videos use `BoxFit.contain` to prevent cropping ## 5. Refactored the Sending Flow The following logic is now centrally managed: * Media source selection * Image / video selection * Video trimming * Media compression * Adding media to the sending queue This simplifies the previous sending flow and compose panel logic. ## 6. Updated Upload Limits * Removed the client-side 10 MB video size limit * Kept the 1 MB image size limit * Larger compressed videos are now allowed to enter the upload queue
Photos & videos Photos & videos
