↳ Reply 5 54 views
Thank you for testing this and for pointing it out. At the moment, the **Navigate** function to a saved location only creates a **direct straight-line bearing from your current position to the selected location**. It does not automatically calculate a safe route based on water depth, land, obstacles, weather conditions, or other navigational hazards. This is intentional because the chart and related data sources used by SeaChart clearly state that they **must not be relied upon for navigation or automatic route planning**. For this reason, SeaChart currently does not attempt to generate an automatic “safe route” around land or shallow water. For actual route planning, I recommend creating or editing a route manually in the **Route** dialog first, adding the necessary waypoints to avoid land, shallow areas, or other hazards, and then starting navigation along that route. Alternatively, you could record a route during a trip and then use that recorded route for navigation the next time you travel the same way. Thank you again for the feedback.
