↳ Reply 8 42 views
Wow, this is actually quite a big task When I originally designed this forum, I honestly did not expect there would be so many posts and discussions, so I will need to think carefully about how to reorganize and improve it. At the moment, the forum is already paginated. It only loads around 20 posts at a time, and more posts are loaded only when you scroll close to the bottom of the page, so it should not normally cause performance or freezing issues even as the number of posts grows. That said, your suggestions are very good. Categories such as Announcements, Installation & Usage, Bug Reports, and Feature Requests, together with search functionality and better desktop/web access, would definitely make it much easier to use. I will seriously consider upgrading the forum experience. I am also considering renaming the current “Forum” to something more like **Feedback Center**, because that is closer to how it is currently being used. In the future, I may introduce a proper community forum as a separate feature — or perhaps something more casual, similar to a community feed or “Moments” page. Thank you again for the suggestion. I will need some time to plan this properly.
