↳ Reply 22 24 views
## Version 2.1.0 Release Preview We have recently received a lot of feedback about the appearance and usability of our nautical charts. In response, version 2.1.0 will include a major overhaul of the chart system. This update includes: * A redesigned nautical chart style to make navigational marks, marine areas, and other chart information clearer; * New colour overlays for depth charts, making different depth ranges easier to distinguish; * An upgrade to the latest version of the base map; * Adjustments and improvements to the bathymetric data for better readability and presentation. Unfortunately, due to significant changes to the new map data structure and styling system, previously downloaded maps will no longer be supported. After upgrading to version 2.1.0, you will need to download your maps again. **Version 2.1.0 is expected to be released in early August 2026. Please be prepared to update and re-download your maps.** We understand that this may take some time and use additional mobile data, and we sincerely apologise for the inconvenience. We hope the updated charts will live up to your feedback—and at the very least, look much more professional than before.
## 2.1.0 版本发布预告 近期我们收到了不少关于海图显示效果的反馈,因此在 2.1.0 版本中,我们对海图进行了较大幅度的调整。 本次更新包括: * 重新调整海图的整体样式,使航标、海域和其他海图信息更加清晰; * 为深度图增加颜色覆盖,不同水深区域将更容易分辨; * 将底图升级到最新版本; * 优化并调整部分水深数据,提高显示效果和可读性。 不过,很不幸,由于新版地图的数据结构和样式发生了较大变化,旧版本下载的地图将不再受到支持。升级到 2.1.0 后,您需要重新下载并更新已有地图。 **2.1.0 预计将在 2026 年 8 月初发布,请提前做好重新下载地图的准备。**我们知道这可能会消耗一些时间和流量,对此深感抱歉。 希望这次更新后的海图能够不辜负大家提出的意见——至少看起来会比以前专业不少。
