Thank you for your kind words and support.
At the moment, detailed sonar depth readings are only available for New Zealand. We are currently adding high-resolution multibeam bathymetry data for New Zealand.
Because each country provides marine data from different sources and in different formats, we need to process and convert the data manually into a consistent format. This may take some time.
You can follow our current progress in the ticket titled “Add High-Resolution Bathymetry Data Sources by Region,” which is currently marked as in progress.
